Sign in to follow this
Ratchet9868
Pod HD500x delay preset switching
The only way to keep the delay going after a rig/chain change is by building 2-patches-in-1 presets, ie by taking advantage of the 2 parallel paths to make 2 different rigs, and making them mutually exclusive.
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
Yes you can do that :
Create a patch on channel A with a volume pedal at the end with setting min to 0 and max to 100
Create a patche on channel B With a volume at the end with setting  min to 100 and max to 0
Use the pedal to switch between the  2 channels
You can assign the expression pedal to each amp model's CH VOL.
  • When Amp A is at playing volume, the CH VOL of Amp B is 0, and vice versa.
  • The heel and toe position give you two "channels."
This also frees up blocks. If you're effects aren't too heavy on DSP, it is possible to have effects models on all 8 blocks.
*As long as the delay is after the amp model on Path A or B, you will hear the tail ring out when you switch channels.
