loydall Posted January 7, 2020 Share Posted January 7, 2020 Hi - I want to attach my HX FX to my pedal board - using velcro. I've not found a definitive answer as to whether the screws of the feet on HX FX need to go back in if the feet are removed? I can't see those little screws attaching to anything crucial/structural in the HXFX - surely internals would be connected/mounted internally? Any ideas? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 7, 2020 Share Posted January 7, 2020 I would not replace the screws after the feet are removed just in case the extra length of the screws inside the chassis might contact something and cause a short circuit. Instead I would cover the screw hole with a tiny bit of tape to prevent dust from getting in and then velcro to your pedal board. Quote Link to comment Share on other sites More sharing options...
loydall Posted January 7, 2020 Author Share Posted January 7, 2020 1 hour ago, silverhead said: I would not replace the screws after the feet are removed just in case the extra length of the screws inside the chassis might contact something and cause a short circuit. Instead I would cover the screw hole with a tiny bit of tape to prevent dust from getting in and then velcro to your pedal board. Thanks - yes, this makes sense. Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 7, 2020 Share Posted January 7, 2020 Make sure you keep the feet and screws in case you want to replace them later. Quote Link to comment Share on other sites More sharing options...
rdnie Posted January 8, 2020 Share Posted January 8, 2020 It is OK to put the screws back without the feet, but the screws are there only for the feet. Both ways are fine. (Source: https://www.thegearpage.net/board/index.php?threads/new-line-6-hx-effects-multieffect.1904280/page-51#post-25802683 https://www.thegearpage.net/board/index.php?threads/line-6-hx-effects-owners-hows-it-sound.1908530/page-13#post-25908573) Quote Link to comment Share on other sites More sharing options...
