GUITAR65a Posted January 10, 2020 Share Posted January 10, 2020 Good morning I tried the procedure as in the manual but at the end the pedal goes from zero volume to maximum volume, without intermediate adjustments. I probably didn't apply the procedure well as it was explained in a rough way. Can someone help me? Maybe if you repeat the procedure in a precise and accurate way Thanks Quote Link to comment Share on other sites More sharing options...
Harold Posted January 14, 2020 Share Posted January 14, 2020 In the Volume Pedal setting the min & max position did you adjust that and save tone. That works for me Good Luck Quote Link to comment Share on other sites More sharing options...
johnlovesbeer Posted January 17, 2020 Share Posted January 17, 2020 I think Harold is misunderstanding you. I too have the same problem using the expression pedal for Pitch Glide. I want it to hit all the notes on the way down but it seems to go from minimum to maximum without the values between. Is there a calibration setting anywhere? I can't find one Quote Link to comment Share on other sites More sharing options...
