mcvmcv Posted January 14, 2020 Share Posted January 14, 2020 Is it ok to connect hx stomp through a trs to xlr balanced cable to a mixer’s mic input with global phantom power on? Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 14, 2020 Share Posted January 14, 2020 Yes, it's fine. The one caveat I'd give is that whenever you know phantom power will be running over a TRS connection, you'd want to turn the phantom power on after you plug the cable into the TRS jack. Otherwise, there is a risk that there could an arc when sliding the plug past the terminal inside the jack. 1 Quote Link to comment Share on other sites More sharing options...
