apurplemunky
HX Edit unable to import IR Error -2 out of memory condition.
I am fairly new to using any kind of impulse response with my Helix as I usually use a Power Stage 170 and a 2x12, but I have recently been toying with the idea of trying out some impulse responses, as I had received a few "free" ones from a couple YouTube channels, I decided to load them up in my Helix LT, the one I got from Glenn Fricker loaded up fine. the ones I recieved from Ola Englund however did not, when loading them into HX Edit, 3 of them work fine, the rest give me this error message:
"HX Edit was unable to import IRs into this set due to the following errors:
-2- out of memory condition"
I did some searching around and figured out that I am receiving this error because of the size of the IRs, the ones that won't import are all 237kb, while the ones that worked fine are significantly smaller, at 59kb and 6kb. is there anything I can do to make the larger ones work with my helix?
What format are they? Are they .wav files?
This is just a shot in the dark, but I'm guessing the sample rate is too high, which might explain the larger file size.  The optimal sample rate for Helix is 48.0 kHz 200ms.
