st0rmchaser Posted January 21, 2020 Share Posted January 21, 2020 I have the Spider V 120 amp and was given a Relay G10 for Christmas. Does the G10 talk directly to the Spider V amp, or is there a missing component that I need to purchase? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
Random1643 Posted January 21, 2020 Share Posted January 21, 2020 I have just the G10T , the wireless transmitter, which I understand is one part of the Relay G10 system you're asking about. I plug the G10T directly into my Spider V 120 W amp's 1/4" input jack on the amp's front panel to charge, and then I use with different instruments Works great! I don't have a separate charger as I'm guessing you do. So, my take is you should be good to go. (The amp must be turned on to charge the G10T.) Good luck! Quote Link to comment Share on other sites More sharing options...
