zest Posted January 27, 2020 Share Posted January 27, 2020 Hi! So I'm using an Helix Rack and I want to be able to record with it. I usually record two rythm guitar tracks that I pan hard left and hard right, as i mostly play metal. But I can't do it with the Helix, here's my problem. When I record directly with the Helix as my soundcard or via an XLR into another soundcard (I tried a Scarlet 2i4 and an Audiobox USB) the sound is significantly different when I pan left or right. I tried with Windows 7 and MacOS, using Cubase and Ableton on Win, and Ableton on MacOS. I just would like the Helix to output a real mono sound, so I can record guitars, pan them and have the same sound on both tracks. Maybe I'm missing the obvious here, but could someone help me with this? Thanks! Quote Link to comment Share on other sites More sharing options...
codamedia Posted January 27, 2020 Share Posted January 27, 2020 What measures have you taken to make sure the difference is NOT in your recording rig, but from the Helix itself? 33 minutes ago, zest said: I just would like the Helix to output a real mono sound, so I can record guitars, pan them and have the same sound on both tracks. M If you have used a stereo block toward the end of you path then the left/right output could sound different. Place a MONO gain block set to unity as the last item in the chain. That will force everything to sum to mono before the outputs. Quote Link to comment Share on other sites More sharing options...
lungho Posted January 27, 2020 Share Posted January 27, 2020 I'm just gonna throw some things out there and make sure we're not overlooking the obvious. I've come up with three things to check. 1. Check your inputs within your DAW. I'm not exactly familiar with Cubase or Ableton, but on Reaper, when I create a new track, I have the choice of recording in mono or stereo. By default, the track is mono. You DAW(s) might handle this differently. But your description sounds like you're recording and then panning a stereo track. 2. Does this behavior happen on every patch, even with the factory presets? If not, the issue might be with the routing within your patch. 3. I highly doubt this is the issue but, try a different USB cable. And there's that ninja, Codamedia, swooping in and posting some sound advice as usual :-) Quote Link to comment Share on other sites More sharing options...
rd2rk Posted January 27, 2020 Share Posted January 27, 2020 Here's a screenshot of what the Ableton configuration would look like. If you have a MONO block at the end of your signal chain, all tracks would be identical. Quote Link to comment Share on other sites More sharing options...
