vortex2011 Posted January 29, 2020 Share Posted January 29, 2020 I am trying to figure out whether or not I should be using the global eq and high and low pass filters while recording out of my cabinet. Should I turn it off and leave it bright and hissy then add HP LP filters in Cubase? or leave it on and add more HP LP filters? Same goes for Compressors in Helix, that is what I am trying to figure out. Or is it based on taste. I only have the Global on in a Live Jam session setting, recording is a different story even my patches need to be dialed in differently to sound better in the daw. Here is my signal path Guitar>Helix Rack>Mesa 50/50 power amp>Mesa Cabinet>Mics>Yamaha Mixer>Focusrite Interface>Cubase 10 Artist No I do not use Impulse Responses (haven't learned) or DI Box. I play Metal Quote Link to comment Share on other sites More sharing options...
phil_m Posted January 29, 2020 Share Posted January 29, 2020 Well, you can always add EQ after you record the track. You can't remove it. I'd be inclined to leave the Global EQ off. As far as the compression, it kind of depends. If it's something that you're depending on for your performance and has a major impact on what you're hearing from the cab, I'd leave it on. Quote Link to comment Share on other sites More sharing options...
vortex2011 Posted January 29, 2020 Author Share Posted January 29, 2020 Thanks Phil_m! I'll have to try some tracks with it off vs on. I don't want an over compressed sound by adding compressors in the Helix, mixer and then the DAW. That would be 3 compressors for one track. If I am over thinking this let me know please... :) Thank you Quote Link to comment Share on other sites More sharing options...
