leandrocarvalho Posted January 29, 2014 Share Posted January 29, 2014 can I use my old preset (hre) if I upgrade my regular pod hd pro to a pod hd pro X (I6t)? 1 Quote Link to comment Share on other sites More sharing options...
GlennDeLaune Posted January 29, 2014 Share Posted January 29, 2014 Sure you can. Just rename your patches file extension from ".hre" to ".pxe" Quote Link to comment Share on other sites More sharing options...
mazuwa Posted January 29, 2014 Share Posted January 29, 2014 As you can read here http://line6.com/support/topic/1644-are-presets-interchangeable-between-hd500500x-and-hd-pro/ which is significant for the whole X upgrade: Don't use Setlists, only use single preset files. In the Open menu you should change the file extension filter to All Files to be able to see your "old" HD Pro presets which you have saved before with HD Pro Edit inside the new HD Pro X Edit later. No really need to change the file extensions if you do it that way. But changing file extensions can make it easier, because you would save changing the open filter. Quote Link to comment Share on other sites More sharing options...
