rd2rk Posted February 3, 2020 Share Posted February 3, 2020 Somebody Sticky This! According to the manuals, this doesn't work using Instant Commands "At This Time". I called support to see if that's been fixed, since the manuals are so old, and the tech didn't know. So I broke out the old Radio Shack Multi-tester. It seems to work on both Presets and Snapshots using Instant Commands. EDIT: OK, just called support again, and they're (different tech) telling me that it works on Floor and Rack, but not on HXFX. EDIT REDUX: CONFIRMED - External Amp Switching with Instant Commands on HX FX WORKS! Thank you C4TH! SOMEBODY STICKY THIS! Quote Link to comment Share on other sites More sharing options...
C4TH Posted February 3, 2020 Share Posted February 3, 2020 Just saw your post rd2rk, after seeing your related comment on another users thread. And yes, tested mine with instants, and it works fine. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 3, 2020 Author Share Posted February 3, 2020 Just now, C4TH said: Just saw your post rd2rk, after seeing your related comment on another users thread. And yes, tested mine with instants, and it works fine. Just to confirm: External Amp Switching with Instant Commands DOES work with HXFX? Quote Link to comment Share on other sites More sharing options...
C4TH Posted February 3, 2020 Share Posted February 3, 2020 28 minutes ago, rd2rk said: Just to confirm: External Amp Switching with Instant Commands DOES work with HXFX? Yes it does. HX Effects with Blackstar Ht40, in my case. 1 Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 3, 2020 Author Share Posted February 3, 2020 5 minutes ago, C4TH said: Yes it does. HX Effects with Blackstar Ht40, in my case. Thank you! 1 Quote Link to comment Share on other sites More sharing options...
maxm17 Posted February 5, 2020 Share Posted February 5, 2020 Thanks! The real question is - will it work with Snapshots? That's what the manual says it will not do. Are you guys testing using snapshots? Would love to know! :) Per the manual I downloaded from L6: Pg. 27: Want to save your footswitches for other uses? Command Center MIDI type Instant messages are automatically transmitted when a Snapshot is recalled. (Note that, at this time, Amp control messages are not transmitted per snapshot when assigned to an instant command; only when assigned to a footswitch.) Says the same thing on page 36. Thanks ALL!!! :) My other thread on this, now moved to here: Quote Link to comment Share on other sites More sharing options...
maxm17 Posted February 5, 2020 Share Posted February 5, 2020 Sorry guys. I read too fast because I'm an excitable boy. Looks like it works in snapshots! YAY! Hope L6 tech support put this in their Knowledge base and update the manuals. Thanks everybody for the help. :) 1 Quote Link to comment Share on other sites More sharing options...
