bendagostino8 Posted February 4, 2020 Share Posted February 4, 2020 I have my pod hd 500x plugged into my peavey 6505 with 4 cable method and all of the knobs and switches on my amp do nothing now. Any help would be much appreciated. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted February 5, 2020 Share Posted February 5, 2020 Did you put also a FX LOOP block in the virtual chain as you should have been done to make the 4CM working properly? If the FX LOOP block is missing (or if it is turned off) when using the 4CM the pre-amp part of your amp is bypassed which means that most amp controls can not affect the tone anymore. You can find a 4CM scheme description here: 4 Cable Method _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips Quote Link to comment Share on other sites More sharing options...
