Sign in to follow this
bendagostino8
Can’t control amp while using 4 cable method with hd 500x
I have my pod hd 500x plugged into my peavey 6505 with 4 cable method and all of the knobs and switches on my amp do nothing now. Any help would be much appreciated.
Did you put also a FX LOOP block in the virtual chain as you should have been done to make the 4CM working properly?
If the FX LOOP block is missing (or if it is turned off)  when using the 4CM the pre-amp part of your amp is bypassed which means that most amp controls can not affect the tone anymore.
You can find a 4CM scheme description here:
4 Cable Method
_______________________________________________________________________________________________________________________________________________________________________
All about POD HD500/X
help and useful tips
