Sign in to follow this
rockinb
no sound
hey guys ... embarrassed to ask ... but ... I'm trying out some Brett Shull presets and am not getting any volume/sound from them .... I know it's simple ... but ...
all other pres and snaps are fine ...
Just a shot in the dark but, move the expression pedal to heal and back to toe.  The volume block might be at 0db.
Hmm....just had another thought.  Bypass all of the blocks and see if you're hearing a clean signal.  If you get a clean signal with no blocks enabled, enable each block one by one.  If you're not getting a clean signal with all blocks bypassed, check the input....Multi/Guitar/Aux/Variax etc -and/or- the output level at the very end of each path....it looks like an arrow.
Too bad it's a paid preset or else I'd just say upload it here and one of us will look at it for you.
Just a common one - is there an IR in the preset?
Do you have an IR in that slot?
thx for the help ....  all the pres are sent with the output to XLR only ... changing to ""multi "  solved the problem !
