Roddie Posted February 8, 2020 Share Posted February 8, 2020 Hello, does anyone know if the pod go has an onboard looper? Thanks, Rod Quote Link to comment Share on other sites More sharing options...
silverhead Posted February 9, 2020 Share Posted February 9, 2020 Yes the POD Go includes the 6-switch and 1-switch loopers, each in both stereo and mono versions. Quote Link to comment Share on other sites More sharing options...
Roddie Posted February 9, 2020 Author Share Posted February 9, 2020 Thanks silverhead. Much appreciated. Rod Quote Link to comment Share on other sites More sharing options...
JogNeuch Posted May 4, 2020 Share Posted May 4, 2020 Hello, Does the Pod Go quantize loops redordings ? Thanks Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 4, 2020 Share Posted May 4, 2020 No. The POD Go looper (like all Line 6 loopers in multi-FX processors) has no concept of timing, tempo, or beats. It simply records the incoming signal from the moment you press the Record switch to the moment you press Stop. Quote Link to comment Share on other sites More sharing options...
Dimaension_X Posted May 24, 2020 Share Posted May 24, 2020 Any video tutorials on using the Looper in the POD Go yet? I'd really like to use it for Frippertonic-style improvisation. Quote Link to comment Share on other sites More sharing options...
clintonreese Posted May 25, 2020 Share Posted May 25, 2020 Hello, can someone tell me how to use the Pod Go looper, I have been trying with no luck.... Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 25, 2020 Share Posted May 25, 2020 Have you read the manual sections about using the Looper? After doing that and experimenting with it you can then ask more specific questions if you’re having difficulty. Here’s the basic operations... - add the looper to your signal chain - step on the switch to start recording - step on the switch to stop recording 1 Quote Link to comment Share on other sites More sharing options...
Nylander88 Posted May 25, 2020 Share Posted May 25, 2020 15 minutes ago, silverhead said: Here’s the basic operations... - add the looper to your signal chain - step on the switch to start recording - step on the switch to stop recording Couldn't say it better myself Quote Link to comment Share on other sites More sharing options...
clintonreese Posted May 25, 2020 Share Posted May 25, 2020 Ok thanks.... Quote Link to comment Share on other sites More sharing options...
tomrennebeck Posted July 17, 2020 Share Posted July 17, 2020 On 5/25/2020 at 6:25 PM, silverhead said: Ok. But, how i do add the looper? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 17, 2020 Share Posted July 17, 2020 You add the looper the same way you add any other flex block. Select the block and then select the looper from the model type list. Quote Link to comment Share on other sites More sharing options...
shikawkee Posted July 17, 2020 Share Posted July 17, 2020 If it helps for someone new to the Line 6 topography you add the looper just like any other block and when you click the switch associated with that block the looper parameters pop up on your screen, like with the 6 button rec/overdub, stop/play, once, rev/half time, etc. It makes sense once you pull it up. Quote Link to comment Share on other sites More sharing options...
Wolfy0411 Posted July 31, 2020 Share Posted July 31, 2020 I found the looper but the playback is not continuously; there is pause between the end and beginning of the loop... any suggestions? Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 31, 2020 Share Posted July 31, 2020 6 hours ago, Wolfy0411 said: I found the looper but the playback is not continuously; there is pause between the end and beginning of the loop... any suggestions? That all has to do with the timing of when you start and stop the loop. There’s no other external timing going on, so it probably just means your timing is a bit off. Quote Link to comment Share on other sites More sharing options...
