VanceBowman Posted February 10, 2020 Share Posted February 10, 2020 I am a praise and worship guitarist and occasionally I play electric. I am having trouble achieving the fat, warm, smooth truly clean tone that I hear on the various videos that I am watching. When I am working on designing tones, I listen through headphones. In use at church, we go direct from the line out. I listen through the personal monitoring system. My axe is a Mike Kelley with humbucking pickups. It sounded great through the small Vox amp at the store. Lastly, I have downloaded a few patches designed for praise and worship and they have also fallen short in this regard. I keep tweaking them to make them better to my ears. What I want is a truly clean fat tone that sustains with little to no breakup in the tone. I am not having trouble finding the delay and reverb that I want. I have tried so many combinations of amps and cabinets. Any suggestions would be appreciated. Thank you. Quote Link to comment Share on other sites More sharing options...
bassbene Posted February 10, 2020 Share Posted February 10, 2020 In general, the following parameters can be used to clean up an amp: - reduce Gain (obvious I guess) - reduce Master volume (reduce/avoid power amp saturation, effect depends on Amp model) - increase Bias & BiasX (prevents power amp saturation) - reduce Sag (prevents power amp saturation, maintains dynamics) - reduce Ripple & Hum (this is more to reduce subtle noise) In extremes, this might lead to a harsh and crisp sound. Does not sound like what you are looking for, but "fatness" can be added by some EQ and sustain by a compressor. Quote Link to comment Share on other sites More sharing options...
rvroberts Posted February 10, 2020 Share Posted February 10, 2020 I'm going to disagree with some of the above - but then it all depends on what you call a fat clean sound. I'm thinking the John Mayer type of sound - but you might also be thinking say a very Jazz sound - or a crystal clear hifi type of sound........they are all totally different. All the cleans I like are actually just before the amp produces noticeable distortion. That adds natural compression and subtle harmonic content. Also, volume is unfortunately part of the problem - as discussed here often - thing sound different depending on volume - our hearing is volume dependant - look up Fletcher Munson - it is real stuff most of us learn means any sound created at home needs tweaking - basically you will almost always find yourself reducing tops and bottoms as the volume gets to live level. So keeping all that in mind, I'd start with a fender model, just because most people like fender cleans.(Twin Reverb?) I'd set the gain so it's just distorting and then back it off a tad till you felt that the clean you like is "under your fingers" so a little more enthusiasm might just be adding a hint of grit. To me then, I've got a dynamic interactive amp relationship with my playing. You can make that a little less dynamic, but very player friendly with some subtle compression - you either will or won't like that - you have to play around with the compressors. Also almost no one likes a clean without some reverb - so add that and adjust - plate or spring in legacy section are likely choices. If you want to do fine tuning, you could put an EQ pedal after the amp ( I like the simplicity of the Cali Q as I'm always reducing the lows and fishing in the mids for the exact sound). Obviously you might like to drop the amp/cab default combo and use an IR - but at this stage it's all personal taste. One thing I'd say loud and clear - and something I keep hearing others disagree with - is using high and low cuts. No good guitar sound should have much below 100Hz and much above 6KHz (often 5KHz) if you want a "smooth" sound, so don't be subtle with those low and high cuts! The fender amp thing is just to get you started - you can take the same approach with a Vox or a surprising range of other amps in the Helix. Even some known for their overdrive make good cleans when run clean(ish). The suggestions above will give you the "other" clean - crystal cleans - see how you go! 1 Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted February 11, 2020 Share Posted February 11, 2020 In addition to what has been said already, you might want to check the global "Guitar Input Pad" setting. Activating it gives you more clean headroom, something I find useful for myself. Needs to be said that this is a global thing and hence will affect all your patches. 1 Quote Link to comment Share on other sites More sharing options...
