jakeguitar1324 Posted February 19, 2020 Share Posted February 19, 2020 Hi, Im wondering about using the HX stomp with 2 amps in wet/dry configuration. My thoughts are to use two paths and send each path to a different amp, not sure if its possible though. Is it possible to have this setup: Path A: distortions, Comps etc and send it to output 1 - Dry Amp Path B: Mods, verbs, delays and send to output 2 - Wet Amp Am I going about this the right way or is there a completely different way of routing this? Thank you Quote Link to comment Share on other sites More sharing options...
brue58ski Posted February 19, 2020 Share Posted February 19, 2020 See page 15 of the HX Stomp manual. I'm not sure if this will solve your problem exactly, but it does get you going out of two different outputs. I don't actually own one so I can't check this out personally. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted February 19, 2020 Share Posted February 19, 2020 See the attached example preset. Note that at the merge point, Path A is PANNED full LEFT and Path B is PANNED full Right. Use the appropriate L/R Outputs for the W/D amps. WD Example.hlx Quote Link to comment Share on other sites More sharing options...
jakeguitar1324 Posted February 21, 2020 Author Share Posted February 21, 2020 thanks guys, will try both suggestions out Quote Link to comment Share on other sites More sharing options...
