Sign in to follow this
mbtainton
Powercab vs Monitors in small studio space
Curious what the experiences are from people here. For use in a small studio space (bedroom sized) with volume levels between 80db - 90db, is there much benefit in using a Powercab vs a good set of studio monitors? Other than being able to use the speaker models in the Powercab of course. Is the Powercab worth the cost for this kind of use?
The answer really depends on what else you intend to do with the stuff, if anything... if none of the gear will ever leave the room, then get a decent pair of studio monitors and call it a day. However, if you intend to play elsewhere, and/or with other musicians, then the monitors won't help you much. It's also entirely possible that if you intend to do both, you might need more than one way to hear yourself... especially if you intend to do any home recording. You need a stereo set-up to do that properly, in which case just one Powercab won't cut it either. Needs and usage scenarios dictate the gear...
  • Thanks 1
A good set of studio monitors will reproduce Helix well in an appropriately sized room. And they can be used for lots of other things.
I wouldn’t use a Powercab 212 as a studio monitor though. Although its a FRFR, any FRFR is optimized for a set of usage scenarios, and Powercab is optimized for guitar. I wouldn’t hesitate to use it for a keyboard amp, or for solo acoustic gigs. But I’d probably never use it for a stereo speaker or mixing.
I should probably clarify. It’s not an either / or scenario. I have some studio monitors already that are my main playback device for the Helix. I’m curious about using the Powercab instead of the monitors to give me the “traditional cab” option as well as the mic’d cab option from the Helix. I wouldn’t ever be using the Powercab for traditional studio monitors usage (eg playback of recordings or mixing etc).
Try out the powercab before you buy it.  I have a powercab 112 plus and I think it works great as an FRFR and for IR loading but I don't really like the speaker only option as much.  This is where the Powercab is supposed to sound like an amp without any microphone simulation.  It just sounds strange to me. I've used plenty of real amps and I prefer the sound of the FRFR or IR sims.  They actually sound amazing and it's what I use with a live band.
