mtyrrell1982 Posted February 29, 2020 Share Posted February 29, 2020 I'm running a 1999 Parker fly into the helix, mag pickups in to the guitar input and piezo into the aux input. The cable is a stereo jack to 2 mono jacks. When in the stereo mode, where the outputs are totally separate, I'm getting a crossover between the 2 sets of pickups, even when the input is not part of the signal chain. I realise it is probably a bad cable or jack on the guitar side, but I thought I'd get an easy fix out of the way before getting the soldering iron out! Quote Link to comment Share on other sites More sharing options...
CraigGT Posted February 29, 2020 Share Posted February 29, 2020 How have you got your patch input set? it defaults to Multi which would cause this problem. Craig Quote Link to comment Share on other sites More sharing options...
mtyrrell1982 Posted March 2, 2020 Author Share Posted March 2, 2020 No, they're running guitar and Aux in 2 separate paths... Quote Link to comment Share on other sites More sharing options...
jbuhajla Posted March 3, 2020 Share Posted March 3, 2020 On 3/2/2020 at 3:05 AM, mtyrrell1982 said: No, they're running guitar and Aux in 2 separate paths... Can you post a pic of the signal flow of your preset? Quote Link to comment Share on other sites More sharing options...
bluebirdrad Posted March 4, 2020 Share Posted March 4, 2020 Try this. Go to global settings and look at input/output settings. Go to send/return mode settings. Is it set to AUX? Set it to RETURN. Or vice versa. You can try using a SEND instead of main ouput for your piezo as well. I had a similar issue with HX Stomp and that's how I worked it out. Settings may be a little different on your unit. Quote Link to comment Share on other sites More sharing options...
