ancker
Helix LT 4CM - No Amp Volume Control
I have my Helix LT set up in 4CM with a PRS MT-15 Amp.
Guitar -> Helix LT Guitar Input
LT Send -> MT-15 Input
MT-15 FX Send -> LT Return 1
LT Mono Output -> MT-15 FX Return
This appears to work fine with all of the presets without any Send/Return block in play.
The issue I'm having is that the volume knobs on my MT-15 now do nothing. If I set either or both to zero, I still get full signal. Only the volume knob or pedal adjust the volume.
Do I need a special Send/Return block for this to work properly?
Is this expected behavior?
What am I missing here?
Yes. You need to use an FX Loop block in your preset in order for the 4CM to work properly. Otherwise you're just bypassing your amp's preamp.
Thanks. Sorry for the delay in responding, but this helped.
As a secondary question, do you just build in an FX Loop for all of your presets, or is there a way to selectively disable 4CM?
I suppose I could work up some fun Midi controlled line switcher or something that diverts the signal to the appropriate input on my amp when I select specific presets.
I think the easiest thing to do is to create 4CM-specific presets and have them set up the way you need them, and not try to make the same presets work for different connection scenarios.
If you set-up 4CM properly with your amp, presets that don't use an FX loop will just go straight to the power amp input of the FX return on the amp and bypass the entire preamp section of the amp.
