Bruce_W Posted March 6, 2020 Share Posted March 6, 2020 Anyone have an idea what the best routing would be? Right now I am trying - Guitar -> HXS lmono in -> Hxfx mono in -> HXFX send -> Amp in. and then the HXS in the amps fx loop. What I want to do is use the HXS preamps on some patches and then be able to use HXFX effects also. I hope that makes some kind of sense lol. Quote Link to comment Share on other sites More sharing options...
bsp212 Posted March 10, 2020 Share Posted March 10, 2020 I'm trying to figure out exactly what you're wanting. If I'm correct on this, you're using a regular amp with the HXS in front, using the HXS for preamp modeling, but using the amplifier power amp and cabinet? When you say amp in is that the instrument input or the effects loop of the amp? I'm not sure if this would work or not, but the HXFX has 2 effects loops. You could run the modulation effects (chorus, flanger, etc.) in front of the preamp on the HXS, create an effects loop in the HXFX, and connect it via 4CM to the HXS by creating an effects loop in the HXS. This way your delays, reverbs, etc. will be after the preamp of the HXS, but before the power amp of your amplifier. So signal path would be: Guitar -> HXFX mono in -> HXFX mono out -> HXS mono in -> HXS Mono out -> amplifier in. I I HXFX Send (1 or 2) -------------------------HXS Return Again, I don't know if this would work or not. Quote Link to comment Share on other sites More sharing options...
