Havukruunu
I can't get a good metal sound for recording
Hello all,
I have bought the hx stomp last week. I use it with a guitar Ormsby gtr7 and Reaper tool to record myself. I have a metal project (only for recording) and before I used a Pod HD.
My problem is: I saw a lot of videos / tutorials on how to create tones, I have bought good IRs and I can not have a metal tone that is "naughty" but at the same time "clean" without too much crunchy noises. And my Pod HD was able to doing this. But when I am listening all those tutorials on YouTube, they sound awesome.
Can you please help me? I do not really understand where the problem comes from...
Best
Tulzcha
8 hours ago, Havukruunu said:
Hello all,
Best
Tulzcha
Have you tried using dual amps? That's what I do. Not sure if the stomp does dual, and if it does you'll run out of dsp pretty darn quick, but for Helix Native I use a Line 6 Epic amp alongside a Mesa Dual Rec. Sounds awesome. I'm using an Ownhammer IR that is a Mesa/Diezel V30 blend.
Rev.
Okay great yes it does but indeed you run quickly out of dsp!
If you put 1 stereo IR for 2 amps, does it work or do you need 1 IR for each amp?
Thank you,
Best,
Hugo
You might consider adding Helix Native to your toolbox and use it in dual paths with your Stomp. I’ve done that and also added a Diezel VH4 distortion pedal to the Native path (going into a fairly clean Marshall amp in Native) while running through a high gain amp in the Stomp
I can get a pretty solid metal tone out of just the Revv amp model and a noise gate. Dial the bass down a little, set the gain so pinch harmonics hit easy, set the Aggression parameter to 2, pick a cab you like (I really like the ML Soundlab IRs for everything metal), and go to town. That amp model doesn't even really need a boost for modern tones. But the trick for modern metal having that saturated, yet articulate tone is light comp->OD boost with a bass cut (tubescreamer with the tone up)-> high-gain amp with the gain dialed back pretty low, just enough to saturate with the boost engaged->V30 cab with either an SM57 or a combo of a SM57 and a bassier mic.
5 hours ago, Havukruunu said:
Hello,
Thanks for your answer! Why using the Stomp + the native?
For dual paths.  I was loosely (very loosely) mimicking Adam Jones’ setup.
I have good experience with the friedman amp mode, i feel that this amp really is the best for whatever i try to do.
Compressor->tubescreamer->Friedman->fx loop->v30 IR->EQ. Just remember to cut the high/low on the IR to tighten it all.
Thank you for your answer!
I do not find the Friedman amp in the HX stomp :)
Moreover I don't understand how to use the fx loop and the utility of it.
Thank you!
Try: low/High cut cutting lows to 160-200Hz > Noisegate > TS9 (2.0, 0.0 ,7.0 controls roughly) > Rev Amp model on Agressive 2/Peavy 5150 > Cab V30 or an IR)
I run my Helix directly into my Macbook and use Garageband. It sounds very good. I don't us the LA Compressor it does tighten the sound and make it more aggressive, but at the cost of dynamics. Maybe for Rhythm tracks.
