HD500 doesn´t start
nacho0514
Hi from Argentina.
I´ve been using my HD500 since 2017 without any problem
Last week something happened: I plugged the power unit and the HD 500 kept staying in the "line 6" logo and reset.
I can open the calibration menu and the flash update, but nothing else. I cannot even connect via USB to my laptop.
Is there any solution.
Thanks and sorry for my poor english.
On 3/10/2020 at 11:30 AM, spaceatl said:
try holding the left arrow on power up. This will reset global variables. Usually clears it up.
Tried this and didn´t work.
I cannot even connect the hd500 via USB to my laptop because I cant update the drivers.
so, basically, you are having pc issues as well.
48 minutes ago, nacho0514 said:
I´ve got the original power supply.
they go bad. it is good that you have the original. but things break.
when buying a replacement, you don't want a $10 chinese knockoff.
  • 4 weeks later...
On 3/16/2020 at 5:16 PM, pianoguyy said:
something got lost in translation
you can't flash without usb
Maybe is there a way to use midi to flash memory? Im having the same problem.
If there is what cable should i use , how, where do i get one?
The Monkey application can be used to update several Line6 products for some of which you can also use the MIDI connection to do the flashing (that's why the sentence you highlighted in the above pic says that you can use also the MIDI cable), unfortunately the HD series is not among those, and can only be updated via USB.
All about POD HD500/X
help and useful tips
