michaelbattista Posted January 31, 2014 Share Posted January 31, 2014 I recently purchased a HD500X. I am using it in a 4cm live set up and noticed that once in a while, which I engage the toe switch for the expression pedal (wah) the sound cuts out, the POD emits a high pitched sound, then the POD reboots. It thankfully reopens on the same patch. Kinda sucks in a live performance setting! It happens on a few different patches, not always the same one. Any ideas? Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted January 31, 2014 Share Posted January 31, 2014 It sounds like it's got a defect. I would return it or get it repaired under warrantee if it is new. It should not do that but there is pressure applied to the unit when you engage the toe switch and it is probably causing the thing to reboot. 1 Quote Link to comment Share on other sites More sharing options...
