keir118 0 Posted March 15, 2020 I'm looking to change my rig to make it as easy to transport and set up as possible. Right now I'm running a pedal board into a 6505 and I'm kind of getting sick of lugging a 25KG head in and out of venues and rehearsal and things going wrong at the worst times with my pedal board. So I'm wondering is possible to run the Helix LT with my noise suppressor in the 4 cable method and have the Helix set up so that I can switch between a clean and distorted tone but also have delay, phasor, chorus, volume boost and wah all switchable? Quote Share this post Link to post Share on other sites
cruisinon2 2,532 Posted March 15, 2020 Yes... but if you're intend to use the 4CM, then you're still gonna be stuck lugging a 25kg head around. Quote Share this post Link to post Share on other sites
Fenderflame28 16 Posted March 15, 2020 Hi Kier Yes to all the above. The Helix also does a pretty good 6505 so you could lose the amp altogether or go for a smaller amp that does a clean sound that you like and run the 4CM with that, using the Helix for the 6595 sounds. Quote Share this post Link to post Share on other sites
