Reamp through Waveform 8
nbiglin
Has anyone reamped with the Helix in Tracktion Waveform 8 (might be the same as 10). I've got my two guitar tracks (regular and dry), I just can't figure out how to set the outputs to send those tracks back to the helix.
I use Logic Pro, so I’m not sure how you need to configure the output in Tracktion, but essentially all you need to do is set the dry signal (which you recorded on USB7) to send out on USB 7 and set the input on whatever Helix preset (your re-amp choice) you want to receive on USB 7 as opposed to the usual input block for guitar, or whatever. The re-amped signal is then sent out on USB 1/2. Simply arm a track on your DAW to record that and you have a new guitar sound in the track. Rinse and repeat until you have total guitar mayhem. Most DAWs are similar in how they work.
It may make more sense if you watch this quick tutorial from Sean Halley. Enjoy!
