Help needed- sending midi program changes
merdenoms74
Hi all,
I'm trying to get the Helix to change channels and modes on my DSL40 via midi program changes. This works fine if I set up an instant command for a patch, but I want to be able to change channels with snapshots.
When I'm in Command Center trying to set the command up to a footswitch, I'm using the following settings:
Command- Bank/Prog
Midi Ch- 1 (I know this is correct because it works on Ch1 with an instant command)
Bank CC00- Off
Bank CC32- Off
Program- 0,1,2 or 3, depending on the channel/mode I'm trying to get. Again, I know this is correct because it works for an instant command.
Should I have specific settings for the Banks? Any help will be greatly appreciated.
Okay, so I worked out that when you go into Command Center while in a snapshot, what you see are all the options for that 1 snapshot- not for the entire patch! I really don't understand the way this is set out. Regardless, I have it working now that I realised I can use instant commands because what I'm seeing in Command Center only affects the snapshot that I'm currently on.
