Helix as stereo bus Effect?
loutowart
Im using Ableton Live 10. Usually i will track two rhythm guitar tracks and group them, apply the Pod Fam 2 plugin to the group pan the raw guitar tracks left and right use one amp setup but match tones. POD Farm 2 seems to do this automatically. Im having real trouble getting Helix Native to do this as i assume it has something to do with input blocks or something. I need the raw tracks to process in stereo not stack on top of each another as seems to be happening. What is the proper way to set up the inputs/blocks to facilitate stereo in/out of the plugin? Thank you for any help, this is the only issue keeping Helix from being my "everything" processor.
Right On!! Ok so i think ive got it. Ive done a 'Y' split before two amps, 1 on  chain 1A, 1 on chain 1B. Ive used the 'balance A/B' controls at Y split setting them to L and R. Ive then dropped the 'Merge' block to chain 1B and at each output set them to L and R.
I was hoping to use 1 chain like POD Farm can do but ill trade that to be able to use the HX models. Thanks for the help, and i hope this helps others
