rsvette12 Posted March 31, 2020 Share Posted March 31, 2020 Hi Guys: Just using headphones on a PC with a backing track in a daw - if I play the helix tone sounds great but after I record it the sound of helix track doesnt sound good (the same as what I am hearing) - like a lot of the effects are missing - I just want to do wet recording Any ideas what might be the issue ? thanks much Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 31, 2020 Share Posted March 31, 2020 Please provide some technical details. What computer/OS are you using? What recording program? How is your Helix connected for recording to your PC? Where are your headphones connected? 1 Quote Link to comment Share on other sites More sharing options...
rsvette12 Posted March 31, 2020 Author Share Posted March 31, 2020 Thanks Buddy PC - OS win10 - Studio one - helix connected usb right to computer - Headphone out cable to amps - headphones plugged into amps - 1 preamp little dot iii and an emotiva main amp It records just not the same quality I am hearing real time in headphones Quote Link to comment Share on other sites More sharing options...
silverhead Posted March 31, 2020 Share Posted March 31, 2020 Is Studio One configured to use the Helix and its ASIO driver as the audio input and output device? After arming a track for recording, what are you selecting as the Record Input source? 2 Quote Link to comment Share on other sites More sharing options...
MartinDorr Posted March 31, 2020 Share Posted March 31, 2020 I might be wrong interpreting your audio signal flow, but aren’t you recording USB out, i.e., a signal that stills needs to run through your amps on playback to match what you are hearing in your headphones while recording. Maybe your recording path to your ears is exactly the same as your playback path, but there could be a few pitfalls the way you are monitoring and comparing. 1 2 Quote Link to comment Share on other sites More sharing options...
rsvette12 Posted March 31, 2020 Author Share Posted March 31, 2020 Guys you are the best - Silver you nailed it - I was using asio in daw not helix - much better now - thanks so much :) Quote Link to comment Share on other sites More sharing options...
