Sunwhy Posted April 5, 2020 Share Posted April 5, 2020 does any one notice that if volume pedal switch from 100% to 0% it would affect amp drive / mid setting (i checked on firehawk remote) when i mute volume by volume pedal down , the current tone setting would be affect after volume pedal open (drive / mid would decrease) is it reasonable setting? Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 5, 2020 Share Posted April 5, 2020 Are you saying those parameters are being changed when you move the pedal? Or that they simply sound different? Quote Link to comment Share on other sites More sharing options...
Sunwhy Posted April 5, 2020 Author Share Posted April 5, 2020 thanks for your reply parameters are being changed after volume pedal switch to 0% and switch pedal to 100% parameters are not in the original position , so tone is different to my original setting... Quote Link to comment Share on other sites More sharing options...
phobos1223 Posted June 29, 2020 Share Posted June 29, 2020 Hi, I have the same problem with My FH, here It is the Video, I restored the factory settings and installed the original firmware , also updated to the 1.30 but the problem was not fixed. Quote Link to comment Share on other sites More sharing options...
