Sign in to follow this
Sunwhy
Firehawk Volume Pedal Question
does any one notice that if volume pedal switch from 100% to 0%
it would affect amp drive / mid setting (i checked on firehawk remote)
when i mute volume by volume pedal down , the current tone setting would be affect after volume pedal open (drive / mid would decrease)
is it reasonable setting?
Thanks
Are you saying those parameters are being changed when you move the pedal? Or that they simply sound different?
thanks for your reply
parameters are being changed after volume pedal switch to 0%
and switch pedal to 100%  parameters are not in the original position , so tone is different to my original setting...
Hi, I have the same problem with My FH, here It is the Video, I restored the factory settings and installed the original firmware , also updated to the 1.30 but the problem was not fixed.
