Sign in to follow this
Bangha
Switching between EXP 1 and 2
Hi everyone.
Is there a way to switch from EXP 1 to EXP 2 without having to use the toe switch? If I have volume on EXP1 and want to control something with EXP 2 , without going full volume, how do I do it? Is there a way to switch between them with a footswitch?
Thanks for the help!
Thanks for the replies guys. I guess snapshots are the way to go. Now, Is there a way to switch from EXP 1 <--> EXP 2 from the editor?
Get yourself an external expression pedal so you can run two at the same time. I use Helix Floor with two external expression pedals. I use on board pedal for volume, and the other two for various other effect parameter control. You don't need to spend a bunch of $ either. I use the plastic Line 6 EXP-1 pedals. Had them for years with no issues.
