lechevaliernoir Posted April 15, 2020 Share Posted April 15, 2020 Hello. My pocked POD war in Formware v1.0. I intended to use yesterday Line 6 Monkey to upgrade to last version. It started well, then the Pocked POD screen switch OFF and is no morfe recognized by my computer When I plug the instrument cord it does not switch ON neither. It's like my Pocket POD is dead. Batteries are almost new.... What could I do? Quote Link to comment Share on other sites More sharing options...
daveny5 Posted April 21, 2020 Share Posted April 21, 2020 Did you try it with the A/C adapter? Batteries don't last very long on a Pocket Pod and if you don't unplug the USB cable, the batteries will run down even if it's not on. From the owner's manual: A note about battery life. During normal use, Pocket POD will give you 4-6 hours of continuous use when running off good-quality AAA batteries. Battery life is directly related to the amount of effect processing you’re using at any given time. In particular, Reverb tends to be the most power-hungry effect. If you want to get the longest battery Controls & Connections 1•6 life possible, turn the Reverb knob to its minimum position to turn off the Reverb. Of course, only you can decide whether battery life is more important than great tone Quote Link to comment Share on other sites More sharing options...
