spg244 Posted April 17, 2020 Share Posted April 17, 2020 Pod Go Edit loses connection after a minute or so. Decent laptop, running Windows 10. Using factory USB cable. Updated to latest version and drivers. Suggestions on computer settings, cable issues? Frustrated! Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 17, 2020 Share Posted April 17, 2020 Try a different cable and/or USB port. Quote Link to comment Share on other sites More sharing options...
Pappy35 Posted April 20, 2020 Share Posted April 20, 2020 I have the same problem with my Helix LT and currently have a help ticket in on. This is not just a PODGo issue. I'll post up whatever they recommend if that's permitted. Quote Link to comment Share on other sites More sharing options...
spg244 Posted April 20, 2020 Author Share Posted April 20, 2020 Thanks Pappy. Update, I used a cheap newer computer and it worked fine. Maybe try a newer laptop. Quote Link to comment Share on other sites More sharing options...
Pappy35 Posted April 21, 2020 Share Posted April 21, 2020 On 4/20/2020 at 10:31 AM, spg244 said: Thanks Pappy. Update, I used a cheap newer computer and it worked fine. Maybe try a newer laptop. Funny. I have the problem with my brand new (<2 weeks old) Lenovo Yoga C740 in either of its USB-A ports. My 7 year old ASUS laptop? Connection is rock solid. I was planning to retire the laptop but until I hear otherwise, I guess it's gotten a stay of execution. 8-) PS - I still need L6 to reply because sooner or later the greybeard laptop is going to die. Quote Link to comment Share on other sites More sharing options...
spaceatl Posted April 22, 2020 Share Posted April 22, 2020 Check power management setting on the USB root controller in Device manager... try different ports...Usually, the right hand side port is dedicated, left hand where multiple ports are will have an internal hub...Historically, PODs do not play well with USB hubs If it have USB-C, Maybe try an adapter? Insure that your BIOS, Chipset and other MB firmware is up to date Insure Windows 10 is up to date Quote Link to comment Share on other sites More sharing options...
Pappy35 Posted April 24, 2020 Share Posted April 24, 2020 On 4/21/2020 at 10:56 PM, spaceatl said: If it have USB-C, Maybe try an adapter? USB-c seems to be where everything's going. My Lenovo has two C and two A ports but charging is via the C ports. I wonder if the USB handling for the USB-A ports is "seen" by the laptop like it's on a hub? I used to be a computer guy but that was 20+ years ago and I'm becoming a luddite in this regard now. Are there USB-A/C converters and would that work? WHat about a USB-B to USB-C cable instead of an adapter. Bettter yet, why is Line 6 still using USB-B ports?!? 8-) Quote Link to comment Share on other sites More sharing options...
spaceatl Posted April 27, 2020 Share Posted April 27, 2020 When I said adapter, I meant a cable adapter (USB-A to USB-C). I have have been a developer on Windows and Mac for over 30 years now...Things are basically the same, just the terminology is updated and the scale is a lot bigger. You want a USB-A to USB-C cable adapter...I have not tried a USB-B to USB-C. I don't see why that would not technically work from what I know about USB, but I have not tried that for myself as I have only USB-A to USB-C cable adapters. I use those all the time with my macbook pro as USB-C is all that it has. Just need an adapter cable to whatever you need...NIC, HDMI, USB-A, VGA, power....really dig the unified interface and it will be nice when everything else catches up. Adapter cable has worked for everything thing USB-A I have tried. Not just Line 6 hardware. Methinks Line 6 is using the USB-B hardware on the POD because it is less expensive. Quote Link to comment Share on other sites More sharing options...
kenyap Posted September 18, 2020 Share Posted September 18, 2020 On 4/18/2020 at 1:22 AM, spg244 said: Pod Go Edit loses connection after a minute or so. Decent laptop, running Windows 10. Using factory USB cable. Updated to latest version and drivers. Suggestions on computer settings, cable issues? Frustrated! Thanks I have this same problem. I open up my DAW (reaper) and it works fine. i can record via my DAW. But my Pod Go Edit says 'connection interrupted' within seconds of launching. Have tried Uninstalling and installing software again to no avail. May i know how you fixed this problem? Quote Link to comment Share on other sites More sharing options...
cristt Posted September 20, 2020 Share Posted September 20, 2020 On 9/18/2020 at 3:16 PM, kenyap said: I have this same problem. I open up my DAW (reaper) and it works fine. i can record via my DAW. But my Pod Go Edit says 'connection interrupted' within seconds of launching. Have tried Uninstalling and installing software again to no avail. May i know how you fixed this problem? On 9/18/2020 at 3:16 PM, kenyap said: I have this same problem. I open up my DAW (reaper) and it works fine. i can record via my DAW. But my Pod Go Edit says 'connection interrupted' within seconds of launching. Have tried Uninstalling and installing software again to no avail. May i know how you fixed this problem? usb issues do happen unfortunatly. Tipically might be because of your host system (your computer). First don't connect to a usb hub, connect directly to a usb on the computer (preferabily the ones on the back of the pc if it's a desktop). Try also another usb port if available. And on the laptops disable the usb energy saving. Quote Link to comment Share on other sites More sharing options...
