DigiCol Posted April 20, 2020 Share Posted April 20, 2020 Hi Guys I was wondering if anyone can help me please? I recently picked up a Marshall JMP-1 MIDI preamp and will be running it through one of the loops on my helix floor. The issue I’m having is regarding the helix controlling the preset/patch changes on the JMP via midi. At present when I change an preset on the Helix it will change the patch on the JMP, ie preset 000 on the helix calls up patch 00 on the JMP. My problem is that I use snapshots within a preset and want my snapshot to change the patches on the JMP (ie footswitch 8/snapshot 1 to call patch 1 on the JMP. footswitch 9/snapshot 2 to call patch 2 on the JMP and so on) and not the presets. I have gone into the command Center and tried to assign each footswitch with a midi prog/bank setting but to no avail. Any advice or help would be much appreciated Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 20, 2020 Share Posted April 20, 2020 In Global Settings>MIDI/Tempo set MIDI PC Send to OFF. That prevents Helix from sending the default PC. Quote Link to comment Share on other sites More sharing options...
DigiCol Posted April 20, 2020 Author Share Posted April 20, 2020 8 hours ago, rd2rk said: In Global Settings>MIDI/Tempo set MIDI PC Send to OFF. That prevents Helix from sending the default PC. That’s great thanks. Once I disabled that it stopped the presets changing patches on the JMP-P now using instant commands I can change the patches on the JMP via snapshot changes. Thanks again for your help :) Quote Link to comment Share on other sites More sharing options...
