SmackedActor
10 stompswitch mode on Helix Control?
I always had the Control board setup with 10 stompswitches, no presets no snapshots and I can't seem to get it like that after updating to 2.90. What's going on?
Any help would be apreciated.
The update changed your Global Settings. If you did a RESTORE of the backup that the update told you to make, it should have restored your settings.
Yeah I restored my fresh made backup the second I saw the Tap Tempo Led blinking, I knew my globals needed to be restored. But no luck.
I believe it should been in
menu-global settings-preset mode switches.
The next Stomp Mode Switches is set to 10.
If the settings are right and it still doesn't work, do a factory reset.
If that doesn't work, time to open a support ticket.
Somebody else cured her problems by unplugging USB and re-booting.
Try that before reset.
Try hitting the mode select switch, you're probably in preset mode. I had the same problem.
Thanks Dorfnar, that did it. Wew I wasn't looking forward to wait for another update to fix this :D
Thanks again.
