Rustykuntz Posted April 26, 2020 Share Posted April 26, 2020 So just randomly, the volume knob just stopped working and it just blasts the volume at what my speakers at, anyone know how to fix this? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 27, 2020 Share Posted April 27, 2020 If you just did the update, restore your Global Settings. Quote Link to comment Share on other sites More sharing options...
JLondon Posted April 27, 2020 Share Posted April 27, 2020 My first thought is that you should check your global settings and make sure that the volume knob is set to the output you are using (XLR, 1/4, or whatever). Just set the volume knob to "Multi" and it should fix it unless you have a more serious problem. For instance, if the global setting for the Vol knob is set to XLR or Digital, but you're using the 1/4 output jack, your speakers are going to get 100% volume (line signal) regardless of where the knob is turned. Quote Link to comment Share on other sites More sharing options...
Rustykuntz Posted April 27, 2020 Author Share Posted April 27, 2020 I have the volume knob set to multi and it still doesn't work. It works with the first preset when I fire it up and then i switch presets and the volume knob doesn't work again. Quote Link to comment Share on other sites More sharing options...
Rustykuntz Posted April 27, 2020 Author Share Posted April 27, 2020 4 hours ago, JLondon said: My first thought is that you should check your global settings and make sure that the volume knob is set to the output you are using (XLR, 1/4, or whatever). Just set the volume knob to "Multi" and it should fix it unless you have a more serious problem. For instance, if the global setting for the Vol knob is set to XLR or Digital, but you're using the 1/4 output jack, your speakers are going to get 100% volume (line signal) regardless of where the knob is turned. I have the volume knob set to multi and it still doesn't work. It works with the first preset when I fire it up and then i switch presets and the volume knob doesn't work again. Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted April 27, 2020 Share Posted April 27, 2020 Which firmware version? Quote Link to comment Share on other sites More sharing options...
Rustykuntz Posted April 29, 2020 Author Share Posted April 29, 2020 newest one. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted April 29, 2020 Share Posted April 29, 2020 Steps - assuming that the hardware is showing v2.91: 1- Factory reset. 2- Open a support ticket. Quote Link to comment Share on other sites More sharing options...
elirian666 Posted April 30, 2020 Share Posted April 30, 2020 I've just encountered the same problem. It was very frustrating, at some point it stopped responding to any edits or changing presets. But I closed HX Edit and then restarted a few times and it went back to normal - try that workaround, but I hope they'll address this problem... Quote Link to comment Share on other sites More sharing options...
phil_m Posted April 30, 2020 Share Posted April 30, 2020 22 minutes ago, elirian666 said: I've just encountered the same problem. It was very frustrating, at some point it stopped responding to any edits or changing presets. But I closed HX Edit and then restarted a few times and it went back to normal - try that workaround, but I hope they'll address this problem... Have you installed the 2.91 hotfix? It should take care of this issue. Quote Link to comment Share on other sites More sharing options...
elirian666 Posted April 30, 2020 Share Posted April 30, 2020 Just installed it, thanks for the tip! Hopefully the problem will not reoccur. :) Quote Link to comment Share on other sites More sharing options...
