Possible 2.91 Bug with HX Effects
MarcG28
So after updating to 2.91 I was trying to put some of the snapshots in the stomp box mode and I noticed that if I tried to put a snapshot on switch 4, the bottom left button, the LED would not work however the commands worked fine where as Switches 2 and 5 worked like normal with the same settings....
Am I doing something wrong or is it supposed to work like that for some reason?
I have the exact same issue with 2.91 on my HX Effects.  The LED doesn't work correctly when a snapshot is assigned to FS4.  The on/off state of the LEDs is correct for the other switches that have snapshots assigned to them, though they do not honor custom colors selected in HX Edit.  I also have issues with a snapshot assigned to FS5 taking two taps to activate.  It's weird that it's specific to certain switches, FS1-FS3 and FS6 seem to be ok other than the custom colors.
Guys,
If you suspect this might be a bug then the best place to post your comments is in the "Helix Bug Reports" thread that is pinned at the top of this forum. I know it says Helix in the title. but it covers all the HX products.
Stay safe.
