Sergioedem Posted May 1, 2020 Share Posted May 1, 2020 Hi, guys! Maybe somebody faced a similar issue. I have an old Line6 Backtrack - https://www.amazon.co.uk/Line-BackTrack-Guitar-Riff-Recorder/dp/B001ELJTCY When I connect it to the computer it doesn't see MARKED and UNMARKED folder. I changed settings in Windows so I could see hidden folders but it doesn't help. I've created a marked folder, Windows suggested to rewrite it, I did it, but folder again disappeared. Could somebody help with it? Quote Link to comment Share on other sites More sharing options...
Sergioedem Posted March 27, 2021 Author Share Posted March 27, 2021 Checking file system on G: The type of the file system is FAT32. One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue. Windows will now check the disk. Volume Serial Number is 9CB2-C2A3 The size of the \USER\.MAP entry is not valid. The size of the \MARKED\.MAP entry is not valid. The size of the \UNMARKED\.MAP entry is not valid. Removing nonvalid long folder entry from \UNMARKED... Removing nonvalid long folder entry from \UNMARKED... Removing nonvalid long folder entry from \UNMARKED... Removing nonvalid long folder entry from \UNMARKED... Removing nonvalid long folder entry from \UNMARKED... Removing nonvalid long folder entry from \UNMARKED... Windows has made corrections to the file system. 1977352192 bytes total disk space. 90112 bytes in 20 hidden files. 36864 bytes in 7 folders. 1529802752 bytes in 77 files. 447418368 bytes available on disk. 4096 bytes in each allocation unit. 482752 total allocation units on disk. 109233 allocation units available on disk. Quote Link to comment Share on other sites More sharing options...
