Schivosa Posted May 8, 2020 Share Posted May 8, 2020 How can I setup a whammy pedal to change positions quickly in Reaper? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 8, 2020 Share Posted May 8, 2020 Not sure what you're asking. Can you be a bit more specific? Quote Link to comment Share on other sites More sharing options...
lungho Posted May 8, 2020 Share Posted May 8, 2020 59 minutes ago, Schivosa said: How can I setup a whammy pedal to change positions quickly in Reaper? I'm assuming you are wanting to change the pedal position with the Pitch Wham block. This would be done with automation. Checkout Page 43 in the Helix Native Pilot's Guide, found here: Helix Native Pilot's Guide. That should get you headed in the right direction. My apologies if I totally missed the mark. If I did, just reply back with a bit more detailed information as to what you are trying to do. Quote Link to comment Share on other sites More sharing options...
Schivosa Posted May 8, 2020 Author Share Posted May 8, 2020 Thanks. Yes, changing the pedal position is what I'm trying to accomplish. Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 8, 2020 Share Posted May 8, 2020 From the Digitech Whammy manual: MIDI Continuous Control Using MIDI continuous control commands, the Whammy’s Expression Pedal position can be remotely controlled. MIDI CC11 adjusts the Expression Pedal position. A value of 0 on MIDI CC11 corresponds to a toe up position and a value of 127 corresponds to a toe down position. ------------------------------------------ The Digitech Whammy does not SEND MIDI. You'd need to assign an Expression pedal in Helix to operate the Whammy, and record the MIDI in Reaper. Quote Link to comment Share on other sites More sharing options...
Schivosa Posted May 8, 2020 Author Share Posted May 8, 2020 I'm not using an actual pedal. I'm using the pitch block in Helix Native. Do I have to use MIDI CC11 in Native? Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 8, 2020 Share Posted May 8, 2020 6 hours ago, Schivosa said: I'm not using an actual pedal. I'm using the pitch block in Helix Native. Do I have to use MIDI CC11 in Native? You should change the thread title you specified DIGITECH Whammy! Since you're NOT using a DIGITECH Whammy, you can assign whatever CC# you want. Quote Link to comment Share on other sites More sharing options...
Schivosa Posted May 9, 2020 Author Share Posted May 9, 2020 Yeah, sorry about that. It was misleading. I can't find where to change a thread title. Quote Link to comment Share on other sites More sharing options...
