s7nstringsofhell Posted May 10, 2020 Share Posted May 10, 2020 anyone able to help me fix this? I have no idea where to even start? Quote Link to comment Share on other sites More sharing options...
rvroberts Posted May 10, 2020 Share Posted May 10, 2020 Well to start with - what piece of software did this come form? Quote Link to comment Share on other sites More sharing options...
s7nstringsofhell Posted May 10, 2020 Author Share Posted May 10, 2020 18 minutes ago, rvroberts said: Well to start with - what piece of software did this come form? latency monitor Quote Link to comment Share on other sites More sharing options...
rd2rk Posted May 10, 2020 Share Posted May 10, 2020 Latency Mon is a great program for telling you that SOMETHING is wrong. If you're a real geek you might even be able to figure out how to fix it. You didn't provide much detail about your system, so I'm going to assume that: 1) You're running a fully patched Windows 10. If not, get Windows 10 and install all the latest patches and drivers. W10 has many audio improvements over previous versions. 2) You have at LEAST an i5 processor and 8 gb RAM. If not, consider a HW upgrade if none of what follows fixes your problem. MINIMUM STARTING POINT - Disable Start-up programs. Only what you ABSOLUTELY NEED! Disable Power Saving. Control Panel/Power Options, choose the High Performance Power Plan. In Control Panel/System/Advanced System Settings/Advanced/Performance/Settings/Adavanced/Processor Scheduling set "Adjust for Best Performance" to "BACKGROUND SERVICES Disable wireless. BUY a wire to connect to your router if you have to. REQUIRED READING https://support.presonus.com/hc/en-us/articles/360025279231-Optimizing-Your-Computer-for-Audio-Windows-10 https://support.focusrite.com/hc/en-gb/articles/207355205-Optimising-your-PC-for-Audio-on-Windows-10 https://www.sweetwater.com/sweetcare/articles/pc-optimization-guide-for-windows-10/ https://helpcenter.steinberg.de/hc/en-us/articles/360008589880-Windows-10-How-to-set-up-and-optimize-a-Digital-Audio-Workstation-DAW- https://forum.ableton.com/viewtopic.php?t=222241 You'll notice that they all suggest certain things. Do them After you've done all of that, re-run Latency Mon. Quote Link to comment Share on other sites More sharing options...
s7nstringsofhell Posted May 10, 2020 Author Share Posted May 10, 2020 8 minutes ago, rd2rk said: Latency Mon is a great program for telling you that SOMETHING is wrong. If you're a real geek you might even be able to figure out how to fix it. You didn't provide much detail about your system, so I'm going to assume that: 1) You're running a fully patched Windows 10. If not, get Windows 10 and install all the latest patches and drivers. W10 has many audio improvements over previous versions. 2) You have at LEAST an i5 processor and 8 gb RAM. If not, consider a HW upgrade if none of what follows fixes your problem. MINIMUM STARTING POINT - Disable Start-up programs. Only what you ABSOLUTELY NEED! Disable Power Saving. Control Panel/Power Options, choose the High Performance Power Plan. In Control Panel/System/Advanced System Settings/Advanced/Performance/Settings/Adavanced/Processor Scheduling set "Adjust for Best Performance" to "BACKGROUND SERVICES Disable wireless. BUY a wire to connect to your router if you have to. REQUIRED READING https://support.presonus.com/hc/en-us/articles/360025279231-Optimizing-Your-Computer-for-Audio-Windows-10 https://support.focusrite.com/hc/en-gb/articles/207355205-Optimising-your-PC-for-Audio-on-Windows-10 https://www.sweetwater.com/sweetcare/articles/pc-optimization-guide-for-windows-10/ https://helpcenter.steinberg.de/hc/en-us/articles/360008589880-Windows-10-How-to-set-up-and-optimize-a-Digital-Audio-Workstation-DAW- https://forum.ableton.com/viewtopic.php?t=222241 You'll notice that they all suggest certain things. Do them After you've done all of that, re-run Latency Mon. 16 gb ram windows 10, i7 8700k so i am good there ill check these steps thanks Quote Link to comment Share on other sites More sharing options...
