joshfass 1 Posted May 11, 2020 Greetings friends, I just took delivery of my POD Go. Super excited to explore and create, but I have a problem with how to integrate with my Digitech Trio+ (plus) Looper. There is a lot of great information for connecting with the Helix, but not yet anything for POD Go. Guitar signal is supposed to go straight from guitar into Trio+. Trio+ has FX send and FX return. Can anybody provide the right routing, inclusive of Trio+, POD Go, and Amp (Fender Deluxe Reverb '68 Reissue). Thanks so much, Josh Quote Share this post Link to post Share on other sites
voxman55 47 Posted May 15, 2020 I'd be interested in this too as for home use I was contemplating getting a Digitech trio to go with Pod Go which would give 'intelligent' drum and bass backing and an independent looper which would avoid having to use the Pod Go looper that uses up a valuable 'block'. Quote Share this post Link to post Share on other sites
joshfass 1 Posted May 15, 2020 @voxman55 I figured it out!!! and this rig is AWESOME!!! Guitar > Trio+ (Guitar In) Trio+ (FX Send) > Pod Go (Guitar In) Pod Go (Main Out - Mono or Amp Out) > Trio+ (FX Return) Trio+ (Amp Out) > Amp Additional notes: I run the bass and drums through the Trio+ Mixer Out to a small 2nd amp. It keeps those sounds clean and unaffected by the Pod Go tones. This also ensures that the Trio+ effects are turned off, so they don't interfere with the guitar tone. I had tried to run the Trio+ in the Pod Go FX loop, but it doesn't work nearly as well Trio+ "learns" better with the dry signal from the guitar. I found it a bit too "toe tappy" to have to have to select "mono FX loop" on the Pod Go, in order to bring the Trio+ into the loop. 85% of my playing time is at home, and given that I have a Fender Deluxe Reverb '68 Reissue, it is way too loud to play with the volume where it really "sings", so I play through headphones plugged into the Trio+ Get the audio-technica ATH-M50x headphones - Amazing "cans" for $150 SO SO SO much fun!!! Let me know if this works for you! ROCK ON! - Josh 1 Quote Share this post Link to post Share on other sites
voxman55 47 Posted May 15, 2020 Thanks @joshfass great to hear you figured it out. I have the exact same headphones which are great sounding but are just a touch too big for my head - even 'closed' they are not a tight enough fit but I manage. I like that you get both a straight and curly lead with them. Shame you couldn't get the Trio+ to work with the Pod Go as well as you'd have liked. Quote Share this post Link to post Share on other sites
jasontolar 0 Posted June 1, 2020 Thanks @joshfass, I was having trouble with this and followed your instructions, now the pod go and trio+ work perfect. Quote Share this post Link to post Share on other sites
Cre8tivexpert 0 Posted October 20, 2020 Diagram worked like a charm! I can now jam with pod go and the trio! Thanks Josh Fass! Quote Share this post Link to post Share on other sites
js24 0 Posted October 31, 2020 On 5/15/2020 at 1:10 PM, joshfass said: @voxman55 I figured it out!!! and this rig is AWESOME!!! Guitar > Trio+ (Guitar In) Trio+ (FX Send) > Pod Go (Guitar In) Pod Go (Main Out - Mono or Amp Out) > Trio+ (FX Return) Trio+ (Amp Out) > Amp Additional notes: I run the bass and drums through the Trio+ Mixer Out to a small 2nd amp. It keeps those sounds clean and unaffected by the Pod Go tones. This also ensures that the Trio+ effects are turned off, so they don't interfere with the guitar tone. I had tried to run the Trio+ in the Pod Go FX loop, but it doesn't work nearly as well Trio+ "learns" better with the dry signal from the guitar. I found it a bit too "toe tappy" to have to have to select "mono FX loop" on the Pod Go, in order to bring the Trio+ into the loop. 85% of my playing time is at home, and given that I have a Fender Deluxe Reverb '68 Reissue, it is way too loud to play with the volume where it really "sings", so I play through headphones plugged into the Trio+ Get the audio-technica ATH-M50x headphones - Amazing "cans" for $150 SO SO SO much fun!!! Let me know if this works for you! ROCK ON! - Josh Thanks for this! Stupid question... Most of my playing time is at home with headphones on. So does your solution mean that I can use overdrive from the Pod Go, without it distorting the Trio+ drums and bass - and have it coming out of the same output (into my headphones)? Thanks for the help! Quote Share this post Link to post Share on other sites
acuba 3 Posted November 17, 2020 On 10/31/2020 at 11:44 AM, js24 said: Thanks for this! Stupid question... Most of my playing time is at home with headphones on. So does your solution mean that I can use overdrive from the Pod Go, without it distorting the Trio+ drums and bass - and have it coming out of the same output (into my headphones)? Thanks for the help! Also very interested in answer on this question Quote Share this post Link to post Share on other sites
