AZSlinger
Preamp pedal into HX Effects?
Hey guys, so was wondering, has anyone successfully paired a tube preamp pedal (Vai Legacy Preamp) with their HX.  If so, please Obi-wan, you're my only hope!!
Im hoping to go through the HX and slave the power section of my amp.  Thanks guys!
It sounds like you want to use the Vai preamp and HX Effects into the power section of your amp bypassing the preamp of your amp.
You could run the Vai preamp into the HX Effects into the Return of the Loop on your amp. Alternatively, you could put the Vai preamp in the loop of the HX Effects and then the output of the HX Effects into the Return of the Loop on your amp.
I'm using my preamp plugged into fx loop. this way makes me able to use some fx before preamp and others following it (e.g. cab sim when plugged straight to the mixer)
