mc0397mc Posted May 16, 2020 Share Posted May 16, 2020 So it's been a pretty rough month for me. I have discovered as of today all audio (system sounds, youtube/spotify, DAW, straight from from Helix) has a lot clicks, pops and cracks. I have tried to narrow this down and have gone through the following: Tested all audio on brand new AKG headphones connected to helix: clicks and pops Tested headphones on other sources: no issues Tested all audio through monitors (Yorkville YSM5's): Clicks and pops Tested all audio through internal speakers: no clicks no pops clear audio Through this it has been narrowed down to the Helix and for the life of me I can not find anything in the global settings that has changed over night EDIT: I am running a 2017 iMac Processor 2.3GHz Memory 8GB 2133MHz DDR4 Quote Link to comment Share on other sites More sharing options...
silverhead Posted May 16, 2020 Share Posted May 16, 2020 What computer and OS are you using? Quote Link to comment Share on other sites More sharing options...
mc0397mc Posted May 16, 2020 Author Share Posted May 16, 2020 My apologies, I noticed that after I posted. I am running a 2017 iMac Processor 2.3GHz Memory 8GB 2133MHz DDR4 Quote Link to comment Share on other sites More sharing options...
Smj7 Posted May 16, 2020 Share Posted May 16, 2020 Most of the time IME, clicks and pops are a word clock issue. Make sure all digital kit is set to the same sample rate/bit depth and allocate one device to be the the word clock master. I’ve mostly experienced it in pro tools if I have my outboard i/o set to internal and my computer/daw i/o set to internal, I’ll get clicks and pops. When I set my outboard i/o to clock to the incoming digital signal, everything’s happy. Sean Meredith-Jones www.seanmeredithjones.com 1 Quote Link to comment Share on other sites More sharing options...
qwerty42 Posted May 17, 2020 Share Posted May 17, 2020 This issue is a computer one, not a Helix one. Things that can affect this (there are others, but off the top of my head): -buffer set too low in ASIO settings for Helix (this is a computer setting, not Helix setting) — I don’t know if Mac lets you adjust this but PC does -CPU overloads from background processes -OS updates that broke something -WiFi or network adapters (WiFi is especially prone to causing this and it’s typically recommended to disable WiFi adapters on computers built for audio processing) -Sample rate mismatch between OS and other apps trying to access Helix for audio (like Smj7 said above) -Misbehaving apps that are hijacking the audio output (again, don’t know how it works on Mac, but on Windows there is an ‘exclusive control’ option that can affect playback outside of a DAW) -Nearby things that emit R/F like tablets and phones and fluorescent lights, which can inject all sorts of digital noise into signals In short, look for recent changes to your computer and environment, not your Helix. Do you have new devices plugged into USB ports that weren’t there before? Recent OS updates? Phone sitting on desk next to your audio processing gear? Quote Link to comment Share on other sites More sharing options...
