Pod HD 500 fails on Windows 10
JohnnyMP2020
Hi all!
I'm using Pod HD 500 on Windows 10 and suddenly fails since 2 weeks ago.
The driver appears with a yellow question sign on the devices screen
I've reinstalled Windows and the POD drivers and the problem continues (it have been working fine for a lot of time)
Any idea of what could be happening?
Thank you!!!
Thank you for your reply!
I'm using 2 DAWS without changes and suddenly stopped to work. In another computer with Windows 7 works perfectly.
In fact, the device now appears with a yellow question mark. I've tried to reinstall and nothing happens...any idea?
Thank you!
Which DAWs are you using ?  Some of them install a driver called ASIO4ALL.sys which doesn't work well with the PODs.  The typical solution has been to remove the ASIO4ALL.sys driver and only use the driver from Line6.
