Jampzz Posted May 25, 2020 Share Posted May 25, 2020 Hi everyone, I've been recording the helix with cab sims off and introducing them in my daw with the GGD Zilla plugin. Now, i've exported those IRS and when loading them into the unit, no sound is coming through. Other IRS do work, stock cabs too. Any idea? Thanks in advance! Quote Link to comment Share on other sites More sharing options...
Stratocat6 Posted May 31, 2020 Share Posted May 31, 2020 Hey just bought the cab pack and had the same problem after some experimenting I've found that the problem is that the zilla cabs aren't at the same sample rate. To fix this import the ir into the daw and then render them with a 48k sample rate. That should fix everything and you can important them into the unit as normal. 2 1 Quote Link to comment Share on other sites More sharing options...
Jampzz Posted June 1, 2020 Author Share Posted June 1, 2020 On 5/31/2020 at 9:01 PM, Stratocat6 said: Hey just bought the cab pack and had the same problem after some experimenting I've found that the problem is that the zilla cabs aren't at the same sample rate. To fix this import the ir into the daw and then render them with a 48k sample rate. That should fix everything and you can important them into the unit as normal. Oh man that's it for sure! Gonna try it asap, thank you so much! Quote Link to comment Share on other sites More sharing options...
andonisudu Posted June 27, 2020 Share Posted June 27, 2020 Hello, I've render it in 48000, and it works, but now the IR is like if i had 2 IRs at the same time. Do you know how can I solve this problem? Thank you! Quote Link to comment Share on other sites More sharing options...
