mikehendo
How do you do this?
I wasn't sure how to search for an answer to this question so I thought I'd just ask it - Sorry if it has been asked somewhere else.
When you are in Snapshot mode and you change to Stomp mode and say, turn on a drive that wasn't part of the original Snapshot. Then swap back to the original Snapshot, how do you make the original Snapshot turn off that drive? What I'm getting is the drive saying on when I actually want just the original Snapshot without the drive.
I'll often go to stomp mode just to get a little extra something. I might change quite a bit of the original Snapshot but just want it all to go back to normal when I re-select the Snapshot - You get the idea :-)
Cheers
Global Settings>Preferences>Snapshot Edits>Discard
And while I have you here. All the lights just went out on my footswitches. I'm assuming it's a fault but maybe there's a setting somewhere that I haven't found yet, that kills them? Any ideas? (actually, I'm almost liking it without all those lights)
Cheers
Did you hit the MODE button and switch to Stomp Mode with no footswitches assigned?
No, this is now a global problem with any patch I select. Those suckers are off. There one day, gone the next. I'm guessing it's a fault but as this machine has so many options I thought maybe I'd managed to turn them off myself (I've run the LED test now and there is no response). I'm a new user and I've been fiddling around as I always do when I get a new piece of gear, this has it's dangers :-). I looked thru the documentation but couldn't find that "feature". I know there are undocumented things - like the power up modes for testing, so I thought maybe I had turned these LEDs off inadvertently.
(Truth be told, I actually quite like them off - stops the unit looking like a crashed UFO on stage :-). I've been getting teased and the boys now call it "Mike's Pinball Machine"...bunch of Luddites those boys )
I'm pretty sure it's a fault now so I've opened a ticket.
Cheers
