Mono or stereo in to preamp
PaulTBaker
Does the preamp then cab cancel out stereo blocks before them.  For example, would the signal be changed to mono by the preamp and cab block. So the stereo minator would just mono after the amp cab... So no need in using stereo until after the amp/cab. Is that correct, or am I missing something.
One little clarification -- if you use a Dual Cab block, it is in stereo, with one cab panned hard left and the other hard right. You only get this dual option if your cab block is separate from the Amp block. Otherwise, yes, single cab blocks collapse everything to mono at their output.
