DIY enlarge/raise switchbuttons
Elephantstomp
Hello guys,
I was given so many usefull things here that I like to give something back.
For better handling in the heat of battle I wanted to have the right/left switchbutton of my HX-Stomp a bit higher to avoid switching the middle one by accident.
I found theese stainless steel curtain rod endcaps:
https://www.amazon.de/Endkappe-leicht-gewölbt-10mm-Kleben/dp/B01MDQYGG4/ref=olp_product_details?ie=UTF8&me=
They also are available with a flat top:
https://www.amazon.de/Endkappe-flach-10mm-Stab-Kleben/dp/B01MG5256O/ref=olp_product_details?ie=UTF8&me=
Have a look at the attached pictures!
Inner diameter: a bit wider than 10mm.
Inner height: 10mm
Height of four washers: 4mm
Remaining height inside (corresponds line six switchbutton-head height): 6mm
Building instructions:
Inside theese caps I superglued four washers (all at once an quickliy to get a defined height)
Let dry!
To get the inner diameter of the cap a bit narrower put some superglue on the inner surface.
Let dry!
Put the caps on the switches.
They fit so tight that you shouldn´t get them off unintentionally.
Possibly scratch some glue off to make it fit.
If needed you can remove the caps without a trace.
This works fine for me and looks great and decent.
For the big Brothers of HX-Stomp this could be a cheap second-switch-row solution.
Cheers!
