Wallyg Posted June 8, 2020 Share Posted June 8, 2020 I updated my Helix to 2.92 and all my IR's are messed up and/or unavailable.. Only 2 are available and they are in every patch where I had IR's. All my Ir's are listed but I can't pull them up. I'm sure I must of made an error. I've updated and used Line 6 gear forever and never had an issue. Any advice? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 8, 2020 Share Posted June 8, 2020 You need to install the latest version of HX Edit. Quote Link to comment Share on other sites More sharing options...
Wallyg Posted June 8, 2020 Author Share Posted June 8, 2020 Thanks for the quick response. I did that first. Quote Link to comment Share on other sites More sharing options...
Wallyg Posted June 8, 2020 Author Share Posted June 8, 2020 The problem is with Edit 2.92. My IR's are in my board but edit shows only IR 1024 or IR 2048 no matter what IR is in a patch. The board shows the correct IR. Edit is not reading the IR's correctly. I guess I'll go back to editing and creating on the board. Thanks ! Quote Link to comment Share on other sites More sharing options...
SaschaFranck Posted June 8, 2020 Share Posted June 8, 2020 3 hours ago, Wallyg said: The problem is with Edit 2.92. My IR's are in my board but edit shows only IR 1024 or IR 2048 no matter what IR is in a patch. I don't understand that. What do you mean by "shows only IR 1024 or IR 2048"? What does it look like when you select the IR block? Not like this? Quote Link to comment Share on other sites More sharing options...
calvin11 Posted June 9, 2020 Share Posted June 9, 2020 updated my Helix to 2.92 ... after the update lost all presets ...? any solution for this ? Quote Link to comment Share on other sites More sharing options...
phil_m Posted June 9, 2020 Share Posted June 9, 2020 6 hours ago, calvin11 said: updated my Helix to 2.92 ... after the update lost all presets ...? any solution for this ? Are you positive? Are you running the latest version of HX Edit? In any case, do a factory reset by holding FS9 + FS10 while powering up, and then once everything is booted up again, do a Restore from Backup with HX Edit. Quote Link to comment Share on other sites More sharing options...
Lone_Poor_Boy Posted June 9, 2020 Share Posted June 9, 2020 On 6/7/2020 at 9:42 PM, Wallyg said: The problem is with Edit 2.92. My IR's are in my board but edit shows only IR 1024 or IR 2048 no matter what IR is in a patch. The board shows the correct IR. Edit is not reading the IR's correctly. I guess I'll go back to editing and creating on the board. Thanks ! I might be misunderstanding but... In HX Edit on the computer, it always says 1024 and 2048, and you select one or the other, and the IR's change as you slide the slider with the IR name shown to the right. In SashaFrank's example he has selected '1024' and the IR's name is 'Gen_01_bright', and it's in slot '2'. It confused me as well when I first loaded IR's. rd2rk and malhavok expand on what the 1024 and 2048 mean in a post of mine here: Quote Link to comment Share on other sites More sharing options...
