Sign in to follow this
Wallyg
Musta Got Lost
I updated my Helix to 2.92 and all my IR's are messed up and/or unavailable..
Only 2 are available and they are in every patch where I had IR's. All my Ir's are listed but I can't pull them up.
I'm sure I must of made an error.  I've updated and used Line 6 gear forever and never had an issue.
Any advice?
You need to install the latest version of HX Edit.
Thanks for the quick response.
I did that first.
The problem is with Edit 2.92.
My IR's are in my board but edit shows only IR 1024 or IR 2048 no matter what IR is in a patch. The board shows the correct IR.
Edit is not reading the IR's correctly.
I guess I'll go back to editing and creating on the board.
Thanks !
I don't understand that. What do you mean by "shows only IR 1024 or IR 2048"? What does it look like when you select the IR block? Not like this?
updated my Helix to 2.92 ... after the update lost all presets ...? any solution for this ?
Are you positive? Are you running the latest version of HX Edit? In any case, do a factory reset by holding FS9 + FS10 while powering up, and then once everything is booted up again, do a Restore from Backup with HX Edit.
Thanks !
I might be misunderstanding but... In HX Edit on the computer, it always says 1024 and 2048, and you select one or the other, and the IR's change as you slide the slider with the IR name shown to the right. In SashaFrank's example he has selected '1024' and the IR's name is 'Gen_01_bright', and it's in slot '2'.
It confused me as well when I first loaded IR's.
rd2rk and malhavok expand on what the 1024 and 2048 mean in a post of mine here:
